Red Shift
Tim Ball
How does Red Shift compare to Twinmotion?
I see it’s included with the latest 25 upgrade so which should we use?
Tim Ball
AC26, iMac
User since V5
13 REPLIES 13
poco2013
Mentor
I don't see Red Shift in the latest update. Can someone point me to it? I thought it was to be included in update 3 next year?
Gerry
It's only available for those with subscription and they require a 8 GB graphics card.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
I have a SSA subscription and I see nothing on Archiplus to download. Can you direct me to the link?
Gerry
I think you can change the engine directly from the PhotoRendering Settings window. Unfortunately my MacBook Pro only has 4GB, so I can't see it.
Nope -- I imagine a AddOn has to be loaded first - But don't see any link or info??
Gerry
Jeff Griffin
There was nothing special to download & install, except for the latest Archicad 25 update. Here's where I found it. I haven't had much of a chance to test it out yet.
iMac 27 (2020) 3.8 GHz Core i7; 128 GB RAM; Radeon Pro 5700 XT 16 GB GPU (macOS Sequoia)
MacBook Pro M1 Max; 64 GB RAM; 32-Core GPU (macOS Sequoia)
ArchiCAD 28/27/26/25 Full (back when Full used to mean Full) (latest builds). User since AC12 (2008).
DGSketcher
Legend
Open Photo Rendering Settings. Select Engine: Cineware by Maxon then a bit further down select Renderer: Redshift. I would imagine like many of us, unless you have a TOP specification graphics card then you will be politely told you can't run Redshift. I can't help thinking Redshift will be serving a very limited user group for some time. I have a two year old Mac with an 8Gb Radeon Pro 580X graphics card and it didn't make the benchmark.
I wonder if Redshift will work with the new M1 Pro chips?
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
More info here... redshift-for-Archicad including hardware requirements
