SOLVED!
Remove a text from a layout
Edwarf
How can i remove this text? I can't select it and it appears on all master layouts
1 ACCEPTED SOLUTION
Solution
1. In the Layout Book, select your Layout and check which Master Layout it is based on.
2. Right-click the Master Layout and activate the Master Layout Settings command.
3. The "A1" text appears because the "Align and assign Drawings to a Grid" option is selected in the "Drawing Placement" panel. If you switch to the "Auto arrange new Drawings" option, it will disappear.
1 REPLY 1
Solution
