Removing lines from layout
Trenneth
Hi!
When I copy my drawing from my plane to layout, there are these arrows showing in the copy on the layout. These lines are not present in normal plane view. How do i remove them? See picture for visualization of problem.
David Maudlin
Trenneth:
I think those are Fill Handles, they can be turned off with the View > On-Screen View Options > Fill Handles command.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Trenneth:
Thanks! That helped!
