Removing the plus symbol from Level Dimension
Could anyone tell me how to remove the plus symbol in my level dimension, shown attached? This is a level dimension with <toL1value> autotext.
I can't for the life of me figure out what is controlling this setting.
I have a different .pln file where it's working correctly (dialog also attached), but I haven't been able to identify where the setting is to spot the difference.
Thanks!
1 Solution
James B
You've currently selected just the Level Dimension Text, if you select the Level Dimension itself, the settings dialogue has 2 options to show/hide the +
James Badcock
Go to post
2 Replies 2
James B
James Badcock
Can't believe I missed that! So obvious. Thanks so much!
