Renovation Filter: 'To be Demolished' lines not showing as demolished in Planned Status filter.
Hi there,
Both polylines and regular lines I have selected as "to be demolished" are not showing as red dashed like my walls do in the 'Planned Status' filter.
The lines do show as red dashed when the 'demolition plan' filter is on however.
Does anyone know a way to make this work using the renovation filter?
Thank you!
Check the renovation filter settings.
There is an option in there not to override annotation element - lines.
Thank you Barry, that did the trick!
