a week ago
- last edited
Saturday
Hi everyone,
I’m working on a renovation project in Archicad and have encountered a limitation with the Renovation feature.
My question is: Is it possible to assign different Renovation Statuses to individual components of a single door assembly?
For example, I have an existing door where I need to:
Keep the existing door frame, classified as EXISTING.
Demolish only the door leaf, classified as TO BE DEMOLISHED.
As far as I can tell, Archicad assigns Renovation Status to the entire door object, rather than allowing separate statuses for its individual components.
The project involves a building dating from around 1900, with an existing barn door that has specific historical characteristics. Therefore, I had to model the door manually rather than use a standard door element from Archicad, in order to accurately represent the existing construction.
To achieve the desired result, I had to model the door frame and door leaf as separate objects:
Model the door frame using a slab.
Save the frame selection as a Door object via File → Libraries and Objects → Save Selection As → Door.
Model the door leaf separately and save it as a Door object as well.
Place both objects separately in the model.
Assign EXISTING to the door frame and TO BE DEMOLISHED to the door leaf.
Although this works, it requires additional modelling and object preparation for something that seems like a relatively common situation in renovation projects.
I would appreciate any suggestions or advice from the community.
Thank you!
Friday
Nope.
You could make a wish for this. GS has shown that it is possible for heirachical elements with the addition of componenet level Renovation Status for stairs in the release of AC30 and there have been long standing wishes for a Door and Window overhaul.
Regarding renovations, there is a long term wish for renovation breakdown of Composites and Complex Profiles, which you can see over here.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
Saturday - last edited Sunday
Hi @BIK,
As @Lingwisyer said, there's no official solution for this case, but you can try this one, it may be practical.
-I made 7 copies of the door, adjusted their settings to be as follow,
#3 of them represent only the door frame,
#2 of them represent the existing door leaf with (90°) 2D opening angle
& #2 of them represent the new door leaf with (45°) 2D opening angle.
-I made 4 Phases for the door element using a combination of (Reno Filters & Design Options) as follow,
*In normal case, the original complete door is set to be shown in (00 Show All Elements-Reno Filter & Main Model-Design Option).
**(1) frame set as Existing ...
& (1) leaf set as To Be Demolished ...
Are set to be shown only in (02 Demolition Plan-Reno Filter)
& linked to (02 Demolition-Design Option).
***(1) frame set as Existing ...
& (1) leaf set as New ...
Are set to be shown only in (04 Change Plan-Reno Filter)
& linked to (04 Change-Design Option).
****(1) frame set as Existing ...
& (1) leaf set as New) ...
Are set to be shown only in (05 New Construction-Reno Filter)
& linked to (05 New-Design Option).
- To avoid listing those doors in schedules, you can:
1) Create a new property e.g. (Scheduled) with True/False value
2) Adjust the 7 doors' (Scheduled) property as False.
3) Add (Scheduled) criteria to the schedule scheme and set it to True.
-BTW, to model a custom door leaf you can use that way of (Save selection as door leaf) but for the custom door frame you should use another object creator like:
1) LPM or (Library Part Maker).
2) PARAM-O.
3) GDL.
Hope that helps.
Monday
Why not just change the classification to Opening instead of Door for the parts that you do not want to schedule?
Monday
Hi @Lingwisyer,
yes, Another applicable way I thought about but liked to avoid them completely from scheduling.
