Renovation Visibility
I want to control the visibility of the key notes (Label Tool) so they are visible ONLY on the demolition plan. So I created a layer called "Annotation Text Demo" and put the key notes on that layer, but I cannot seem to control the visibility of the key notes through the layer combination.
The only other way to do it is to select all the key notes and set their renovation status to "To Be Demolished" and the key notes will show only on the demo plan. The problem with that is that the key notes become dashed just like any demo items, and I want them to be solid lines. Any recommendation as to what I need to do. Thanks.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Cheikh,
Use the magical 4th button in the Renovation palette.
HelpCenter - Show an Element in a Single Renovation Filter Only
I hope this helps.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Nicholas,
Thanks. I tried both approaches explained in the link and both worked.
