!Restored: AC10 student: messy JPEG publishing
hi, i've just encountered a weird problem during publishing. My layout is sized 122*165 cm, and when i publish it to jpeg it gets weird. Aside from the usual graphisoft ads on the picture, it isn't sized correctly (photoshop says 119*161.2) any longer and the picture is slightly pixelated, although i had set the option to "highest" on the quality bar. i notices too that the width is exactly 4000 pixels. Is this the maximum ac10 can handle for jpeg? or has this relation to the student version?
thank you
Why are you publishing to JPEG? PDF works much better.
