!Restored: AC10 student: messy JPEG publishing
hi, i've just encountered a weird problem during publishing. My layout is sized 122*165 cm, and when i publish it to jpeg it gets weird. Aside from the usual graphisoft ads on the picture, it isn't sized correctly (photoshop says 119*161.2) any longer and the picture is slightly pixelated, although i had set the option to "highest" on the quality bar. i notices too that the width is exactly 4000 pixels. Is this the maximum ac10 can handle for jpeg? or has this relation to the student version?
thank you
1 REPLY 1
Why are you publishing to JPEG? PDF works much better.
