Roof angle changing hatch output
A quick query: I have two roofs, one set at 5 degrees, the other at 15. Both of their fill settings are exactly the same and the drawing display options are correct. However, the 5 degree roof hatch appears to scale independently and plots out as a 25% fill. See attachment. Any suggestions would be greatly appreciated.
11 REPLIES 11
It seems to sort itself out in V13 if you change the 'Edit Vectorial Patter' to 'Scale with Independent'. Look towards the bottom of the screenshot.
That is it George.
I see my fills are scale independent now but when I look back at an old template they used to be "scale with plan".
Tracking back through my notes I see i did indeed make this change.
Thursday, 14 June 2007 4:36 PM
"Custom orb cladding - vertical" fill type change to not be scaled to avoid elevation / zoom bug.
NOTE - if used as a polygon fill then it will no longer scale.
So that is indeed the solution.
