Roof slope generation automatically in Archicad
ashwanikumarshukla
Please suggest how to show roof slope or ratio in 2d plan automatically. i am wondering. Please suggest.
Ashwani Kumar Shukla
Archicad 12-26, 64gb ram, window 10
Hi there,
This can be achieved by creating a simply IFC Property mapping rule to the Pitch parameter of the roof element. After the IFC Property has been defined you can then link this to the Categories and Properties label to show the IFC property on floor plan.
To achieve this result, follow these steps:
1) Navigate to the File Menu>Interoperability>IFC>IFC Scheme Setup. Highlight IfcSlab and click New Property/Classification. Defined a Property Set name followed by a Property name and click OK.
2) Highlight the Property within IFC Scheme Setup and click New Rule. Click the Add Content button and open up the Roof subheading and add Pitch from the list of available parameters. Close IFC Scheme Setup.
3) Open up the Label tool and choose the Categories and Properties label. Click OK and apply it to the Roof element. Select the label on plan and open up the Label Selection Settings, under the subheading Custom Settings>Content. Set the option Select Data to Create Sorting. Click on 1. ROW followed by the tiny black arrow which points to the right to assign the IFC Property we created in the previous steps. Click OK and you will see the pitch angle shown on floor plan.
Please note this was written for AC20 but can be achieved in AC19/AC18 in exactly the same way as above. However there will be differences in naming conventions.
File Menu>Interopability is File Menu>File Special within AC18/AC19.
Add Content button is Add Parameters within AC18/AC19.
Categories and Properties label is Generic Label within AC18.
Hope this helps.
Kind regards,
Marcus
Pato99
Hey, I tried setting this up ages ago and it didn't work. I'v just seen your post and this is exactly what I'm trying to do.. I wonder if you can clarify your settings a bit more because I get no value.
When I go into the roof properties my Pitch reference is grayed out and wont show as an option in the label.
I'm using AC20 so there shouldn't be much difference. I'm wondering If I have the property type or value type incorrect.
My options are -
IfcSlab
Property Set name: Pset_Draughting
Property Name: Pitch
Property Type: Single Value
Value Type: IfcLabel
Rule > Roof > Pitch
Thanks.
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
