KeesW
Rotate titleblock
How can I rotate a titleblock without rotating the layout view to which it is attached?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
2 Replies 2
Dont think this is the right answer.. but here goes anyway.........
if you go to your masters i nthe layoutbook and select the correct titleblock, you can then make a duplicate and copy and past the title block then rotate 90 degrees.
I think You are talking about the Drawing Title, not the Tittle block.
If you want to rotate the Drawing title, you can go to the Drawing settings, go to the Tittle settings and select a custom rotation...
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
