Rotated dimension problem
Hello, can someone help me this?
I rotated the drawing in the layout sheet and cannot find a way to align the dimension the way I need.
See fig.
Thank you in advance.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Can't you just click on the dimension text, use the pet palette to drag and mirror or rotate the text?
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Yes, but there is no automatic way to make all dimensions of the project, to realign after the rotation?
Thank you for your quick answer. 🙂
kevin b
Not that I'm aware of. I think the proper method would be to rotate the view (and save it in view settings), that way you do have control over orientation of dimension text as you can make it relative to view.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
