2017-05-09 03:40 AM - last edited on 2023-05-22 11:55 PM by Gordana Radonic
2017-05-09 06:42 AM
2017-05-09 07:14 AM
vistasp wrote:Hi Vistasp, the article seems to introduce how to add decimals and round decimals. However, I was wondering if I could round the milimeters instead of decimals. Thanks for the help.
Andy, you need to set your dimension preferences for the project. See this helpcentre article for more.
2017-05-09 07:14 AM
2017-05-09 07:27 AM
sboydturner wrote:As much as I agree with you. I think it makes sense to leave exact dimensions from site boundaries as well. Say 2002mm is fine to indicate a 2 meter setback but it seems some councils prefer to have rounded off dimensions.
Do not round metric dimensions, just draw to the correct size.
If I catch anyone in my office editing dimensions they would get reprimanded, there is too much risk in editing dimensions
Scott
2017-05-09 07:32 AM
2017-05-09 07:54 AM
Barry wrote:Hi Barry, I think that should be the way it is as well, there shouldn't be any problems giving dimensions that are accurate.
No you can't round to 5mm or 10mm, it is millimeters, centimeters or meters and then you can set the decimal precision.
As other have said try not to adjust dimensions - show it for what it really is.
If it ends up something and 12mm from a site boundary then so be it.
At least you are being as accurate as you can be.
The tradie will round it up or down to the nearest 5mm or 10mm no doubt.
