2021-09-19 02:51 AM - last edited on 2023-05-17 02:08 AM by Gordana Radonic
Archicad 20
THE SLAB WILL NOT SH0W IN SECTION BUT IF YOU CLICK ON WHERE IT IS SUPPOSED TO BE IT LIGHTS UP AND SHOWS THAT IT IS THERE.
Slab Floor Settings (Shows in Section) Archicad Grafisoft Naz
Ref Plane = Top
Home Story only
Cut surfaces
Cut Line Solid _
Override cut fills None
OUTLINES
Uncut lines Solid_
Pen .28 2
COVER FILLS X
Cover Fill Air Space
Use Fill from Surface (NO)
Cover Fill Pen .28p 2
Cover Fill Background Transparent 0
Cover Fill Orientation Link to Project origin
MODEL
Conc. Light
Generic Exterior
Ceiling White
Category - Slab
Struct. Load Bearing
Position Interior
Renovation New
Fire Unrated
Construct. Undefined
Conc. Cast in Place Reinforced
Ones that were changed to match one that works.
It still did not show up in section and it is marked as new work.
2021-09-19 06:50 AM
Could it be that there is more than 2 slabs - so deleting one still leaves more than 2 behind?
Try a new section and maybe even one looking in a different direction.
2021-09-20 04:07 AM
Have you checked to see if the slab is intersecting with a wall/roof or slab that is hidden but on the same layer number? I had a similar problem where I had used slabs to do the bulk and massing for a project, put these on a hidden layer but when doing sections they were still stopping the final floor slabs from showing up. By the time I'd gotten to this point I had forgotten I had the bulk and massing as a layer at all. Try opening in 3d with all of the layers turned on and see if there could be any clashes with much larger objects.
2021-09-20 10:55 AM
Try a different building material for the slab and check the current material settings?
2021-09-23 07:31 AM
Yea, usually that is the case when 2 slabs are overlapping with each other.
