SLAB DOES NOT SHOW IN SECTION
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-09-19
02:51 AM
‎2023-05-17
02:08 AM
Gordana Radonic
Archicad 20
THE SLAB WILL NOT SH0W IN SECTION BUT IF YOU CLICK ON WHERE IT IS SUPPOSED TO BE IT LIGHTS UP AND SHOWS THAT IT IS THERE.
- I TRIED ERASING IT TO MAKE SURE THERE WAS NOT TWO WITH EACH ONE HIDING THE OTHER.
- ALSO, I MADE SURE THAT IT WAS NOT SHOWN AT THE WRONG HEIGHT.
- TRIED COPY AND INJECT OBJECT TRAITS BUT THAT ALSO WOULD NOT WORK.
- I ALSO TRIED COMPARISON OF SLAB COMMANDS, CHANGING COMMANDS TO MATCH SLAB THAT SHOWED CORRECTLY. THAT ALSO DID NOT WORK. SHOWN HERE IN RED ARE THE COMMANDS THAT I FOUND THAT WERE DIFFERENT AND CHANGED TO TRY TO CORRECT.
- I ALSO CHECKED TO SEE IF SLAB WAS LISTED AS EXISTING AND IT IS LISTED AS NEW CONSTRUCTION.
- PLEASE TRY TO REVIEW AND GIVE ME IDEAS ON WHAT I AM DOING WRONG?
Slab Floor Settings (Shows in Section) Archicad Grafisoft Naz
Ref Plane = Top
Home Story only
Cut surfaces
Cut Line Solid _
- #1
Override cut fills None
OUTLINES
Uncut lines Solid_
Pen .28 2
COVER FILLS X
Cover Fill Air Space
Use Fill from Surface (NO)
Cover Fill Pen .28p 2
Cover Fill Background Transparent 0
Cover Fill Orientation Link to Project origin
MODEL
Conc. Light
Generic Exterior
Ceiling White
Category - Slab
Struct. Load Bearing
Position Interior
Renovation New
Fire Unrated
Construct. Undefined
Conc. Cast in Place Reinforced
Ones that were changed to match one that works.
It still did not show up in section and it is marked as new work.
- Labels:
Renovation Filter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-09-19 06:50 AM
Could it be that there is more than 2 slabs - so deleting one still leaves more than 2 behind?
Try a new section and maybe even one looking in a different direction.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-09-20 04:07 AM
Have you checked to see if the slab is intersecting with a wall/roof or slab that is hidden but on the same layer number? I had a similar problem where I had used slabs to do the bulk and massing for a project, put these on a hidden layer but when doing sections they were still stopping the final floor slabs from showing up. By the time I'd gotten to this point I had forgotten I had the bulk and massing as a layer at all. Try opening in 3d with all of the layers turned on and see if there could be any clashes with much larger objects.
Windows 10 Pro 1909
Intel Core i7-6700; 32GB RAM; AMD RX480
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-09-20 10:55 AM
Try a different building material for the slab and check the current material settings?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-09-23 07:31 AM
Yea, usually that is the case when 2 slabs are overlapping with each other.
