Hello everyone,
I Hope you are all doing well!
I came across a very unusual problem while publishing a drawing. Of three i needed to publish to DWF format, two did so flawlessly until the last drawing that looked like the A_DWF attachment when it should look like the A.pdf attachment.
I found this crazy and tried every option in the DWF publisher options and all yeild the same results. I´ve tried saving both to a server path and a local PC path and nothing changed.
Have any of you had a similar issue?
Cordially,
Michael
