Scale Sensitive option not working correctly
I'm a newbie to ArchiCAD however there seems to be a bug in the program. I have created a window using the W1 casement from the library. Under the Window Selection Settings-Parameters I have set the Option to Scale sensitive. However when I change the view settings to different scale settings ie: 1/8" I am still getting the windows showing with casing and jamb detailing. It's just way too much detail for 1/8" scale. Is there any way to make it appear with less detailing without having to set the option to "Simple".
ArchiCAD 9.0 (w/ latest hotfix) on PC Windows XP (SP2)
1 REPLY 1
This thread may be of interest.
http://archicad-talk.graphisoft.com/viewtopic.php?t=5804&start=10&postdays=0&postorder=asc&highlight=
