Schedule Criteria based on if element is Classified
It would be good if there was a criteria in schedules that was something to the effect of "if the element is classified include it".
You can filter if an element is in a branch of a classification scheme, but you would have to have as many of these criteria lines as you do classification branches (hope that makes sense).
Our work around is to create a property called "is classified", make that property available for all classifications.
In the schedule add criteria that if the property "is classified" is "available" then include.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
2 Replies 2
Does classification 'has value' work?
Would this include any items that has any classification?
You're a legend! Can't believe I've overlooked that option.
Appears to work, I'll comment back if there's any issue.
