Schedule of Zone areas to show Sub Totals not Grand Totals
Josh Verran
I have various schedules set up to read the Areas of zones, broken up by zone category (eg Buildings and Decks).
I need to see the total area of buildings and also the total areas of Decks.
I don't want to see the total area of buildings and decks combined.
I have tried various combinations withing the schedules but not having any luck.
In the past, I have made the Grand total white, but seems a bit low-tech and has its own issues.
Any suggestions?
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
4 REPLIES 4
If you are summing and using the flag to group values, I don't think there is any way to have a sub-total without a grand-total.
However in the format settings, try selecting the grand total and making the row height very small, and/or the font small and white pen.
That might hide it.
Liamthanks
You could categorize the zones and have 2 seperate schedules, one for building and the other for decking.
AC27 Build 5060 AUS - Windows 10 Pro, Ryzen 7 5800X, RTX 3090, M.2 NVME 0.5TB SSD, 32GB RAM
Great Idea Barry - this has drove me nuts for years...
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
Somewhat risky if the number of zones changes, but I’ve typically cropped the placed schedule on the layout to crop off the grand total.  If Barry’s idea works, it would be a better option as the full schedule would always display even as the number of zones changes and or you change other formatting.
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
