Section - Fade away with distance from section cut
Is there a way to make the buildings in section brighter, as they are more distant. For example, i cut where a building A is near and the line appear black and the ones behind begin to fade away, according to the distance they are from the building 1. Black to grey, as the distance from the section increases. Thank you.
Here is the example, with a grey scale elevation
2 REPLIES 2
Eduardo Rolon
There is only one level that you can create using the 'Mark Distant Area' option for the section.
If you wan to create multiple levels you can create pairs of sections (each will have 2 different pens weights) and put them one behind the other in the Layout.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
RandyC
You could use a masking fill - Linear Gradient or Radiant Gradiant with white
to create a fade-out effect.
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
