Section GO
Nicholas Jones
Hi everyone,
I posted about this a few days ago, didn't get any solutions but used a temporary fix and got on with it.
Lo and behold, a new project, same issue. This is getting frustrating because I usually don't doctor elevations with fills but it's now part of my workflow since 24!
Here is the issue again, why aren't the override options in the section settings working for cut surfaces? below I have set it to cut fills, seems ok.
Then with own surface colours, great it works.
but when I go to override the surface, it won't change. this has never happened to me before I hope I'm missing something obvious.
I am on AC24 on a MacBook Pro 2017. Any help is very much appreciated.
AC25 solo UK • 2017 MacBook Pro 15" 2.9GHz Quad-core i7 16 gb ram
OSX10.15.5
5 REPLIES 5
David Maudlin
Nicholas Jones:
FWIW, I am seeing the same result as you in AC24, AC23 works as expected. I don't know of there is some other setting that affects this, or it is a bug.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Nicholas Jones
Thanks for getting back to me David,
I believe it is indeed a bug as the section override should be at a higher priority to other overrides.
Hopefully will be looked at soon, I have set up a GO workaround for now.
OSX10.15.5
David Maudlin
Nicholas:
Someone from Graphisoft may see this thread on the forum, but the best way to report a bug is through your local reseller.
Thanks for adding your signature.
I will report it to Graphisoft.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Nicholas,
I believe this is the same as the question posted here: https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=70764 ?
If that is the case, this is a defect with AC24. Unfortunately, the only workaround for now is applying Graphics Override to cut surface, instead of using Cut Surface override in the Sections.
Thank you very much for your understanding!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
