Section not showing fills beyond
When I cut a section the surface hatches beyond are not showing up. I never used to have this issue, but have been having it happen in multiple projects now. They show up fine in the elevations, just not in the sections. Any ideas of where to look to change this setting so it shows correctly?
In section settings under the Model Display tab there is a checkbox in the Uncut Elements section for Vectorial 3D Hatching (1). If this is checked you will also have an option to turn on hatching in the Marked Distant Area display too (2). One or both of these may be turned of in your section.
Perfect! That was it! I thought I tried that yesterday, but I guess not. Thank you so much! Here's what it looks like in ArchiCAD 20 for anyone else who has this issue.
