2004-06-22
		10:37 AM
		2023-05-30
		12:29 PM
			Rubia Torres
2004-06-22 12:33 PM
2004-06-22 05:43 PM
Matthew wrote:Well, it's a surface model from Rhino and I don't want any section depth because I want the mountain to show as a simple line.
How is it modeled? If it is a surface model it may not show in a zero depth section.
The quick and dirty fix is to just give the section cut a little depth.
2004-06-23 12:09 AM
2004-06-23 10:51 AM
mathome wrote:Check the length, width, and height of the object in the Object Settings. Do the values seem to correspond to the actual object size? Does it display hotspots which encompass the entire object? If the object bounds are incorrect, ArchiCAD might calculate that the section line does not pass through it and consequently omit it from the section.
I have modelled a mountain side as a gdl-object and I want to show it in section but I don't want any section depth. When I choose no section depth the mountain object doesn't show.
