We value your input!
Sections and Elevations using Renovation Filter
Hi
I'm using Archicad 21, and I've tried a lot of different solutions and unfortunately all of them didn't work.
I'm using renovation filters and what I want is simple.
When in a section or elevation I what to see at the same time the reds (new elements) and the yellows (demolished elements). Is it possible?! How can I configure the renovation filters option to that result?!
Thanks
1 REPLY 1
I assume you already have your "New Elements' override style set to be red and your "Elements To Be Demolished' override style set to be yellow.
Then you create a renovation filter that will 'Show' existing, "Override" new and 'Override' to be demolished.
Set that filter in your elevation and you should have what you want.
