Selections not working correctly in ONE elevation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-01-12
11:34 PM
2023-05-23
03:04 AM
Gordana Radonic
Archicad24 on mac
Mac
Archicad 26
- Labels:
Elevations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-01-13 03:18 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-26 04:21 PM
Mac
Archicad 26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-27 01:50 AM
However, sometimes the reason is just a glitch in Archicad, or it may be caused by other things, e.g. a display driver error. And sometimes it does happen that some data within Archicad gets corrupted. I would say that in this case, it was probably not caused by some setting in Archicad which you could have discovered and modified. This happens sometimes, and if it can be easily remedied by simply recreating the Elevation, then there is probably no more reason to worry about it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-03-18 05:44 AM
I had the same issue in AC24. Prior to this I have never had this problem. Unable to select the element e.g. roof, but able to select text or a fill. The answer for me (thanks to our BIM manager Myles) was that the section or internal elevation (or elevation I guess) had a limited height set to 0 and 0. (zero,zero). If you set it to unlimited then it works.
Is very annoying. I have not experimented beyond this. Good luck.
Raoul
x64 Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz, 3696 Mhz, 6 Core(s), 12 Logical Processor(s) 32gb RAM Nvidia Quadro P1000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-03-18 07:11 AM
And it was still displaying somethings, just nothing was selectable? Interesting.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-03-18 08:23 AM
Interesting or a bug?
You can't have a zero width section/elevation.
But if the top and bottom heights are the same (i.e. effectively zero height), it shows the entire height but still crops the width.
Why not just a warning to say it can't be done?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-03-18 09:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-03-24 11:49 AM
Thank you very much for your opinions about this problem!
We have discussed it and agree that it makes little sense to have Vertical range limit to 0 but the whole model is still visible. I will ask the developers about this function, why it behaves like this. As soon as I have the answer I will let you know!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-03-25 01:24 AM
Lingwisyer wrote:You can select, but you have to window the elements (be they 3d or 2d) to select them.
Raoul
