‎2004-11-05
02:27 AM
‎2023-05-23
03:15 AM
Gordana Radonic
‎2004-11-05 02:36 AM
‎2004-11-05 02:48 AM
‎2004-11-05 09:14 AM
Ultimately i would like to do a elevational drawing of the adjacent building facade which shows what shadow impacts of the proposed building.
‎2004-11-05 10:39 AM
‎2004-11-07 11:09 PM
Susanne wrote:the elevation marker only produces shadows from building in front of the marker. However i want to produce shadows generated from buidlings behind the marker. unless this has changed in v9 as i am still in 8.1if you have both buildings as models and draw an elevation marker with "Infinite" depth + go under the Model Effects' settings for your elevation marker and check "Vectorial 3D Hatching" option. You'll then get shadow castings on your buildings - use 3D window's sun settings or make "custom" settings for it under Elevation tool's Model Effect settings as well ...
‎2004-11-07 11:14 PM
David wrote:david,
go to arkiklub.com and download the example PLA this takes you through the whole process
