Sheet Index
In AC22, I cannot get my sheet index to show only the sheet id and name once. It shows multiple copies of the name with the same ID based on how many items are references on the drawing sheet. How do I fix this?
1 REPLY 1
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
I cannot see your index settings in this picture, but my guess is that you are listing the drawings and not the sheets. The only reason they all look the same, is that you only listed the layout info of each drawing.
If you check this, and find it is not the case, then please send me the file and I will take a look at it.
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
