dhnguyen
dashed line in demolished wall
I want to reduce the spacing of the dashed line when an existing wall is has a renovation status as "To be demolished", how do I do that?
Thank you.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Eduardo Rolon
You will need to create a New Line Type and edit the spacing there then you can assign that LT to the override settings for Demolition. Check under menu Options-> Lines.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
dhnguyen
thank you!
DNguyen
ArchiCAD 18- 25
