dhnguyen
Door
First of all, I cannot select this door to look at its property - how do I do that?
Second, how do I change the color settings of the door from green to another color? I tried looking in Model View Options and it shows door opening line as pink. - nothing in renovation override styles would indicate that they're green for me to change the color.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
3 Replies 3
Eduardo Rolon
Door Opening lines are controlled in Model View Options under Document-> MVO-> Miscellaneous Settings for…
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
dhnguyen
I don't have miscellaneous settings in ACAD 18 under MVO. I figured it out. If i hovered the mouse long enough, I will be able to select the door and edit its properties, thank you.
DNguyen
ArchiCAD 18- 25
Eduardo Rolon
Hmm, you should have that setting under MVOs since AFAIK it has been there since forever. It might have a different name since AC2018 is 4 versions old.
Anyway that type of setting should be controlled using MVOs instead of individually per object.
AC29 US/INT -> AC08
another Moderator
