Side dimension in building section
Hello, i would like to know how do I delete those side-dimensions marked in red, in my building sections. Thanks for answering
5 Replies 5
Right click in Section and choose "Hide Story Levels...."
I tried this but it doesn't work for me.
I right-click in an Elevation and select Hide Story Levels in this Section/Elevation.
The Story Levels do not disappear.
I have to go to the Elevation Settings Dialog and set the Show Story Levels field to None in the Story Levels panel.
Does this work for you Andro?
May be a bug.
Laszlo,
yes it works for me , but in AC15. No luck in AC16. It must be a bug.
Yes, doesn't work for me in AC16 either.
I will report this to GS.
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Thank you for your remarks, I have added your reports to the existing issue in our defect database.
You can hide the story level lines from the Section/Elevation/IE settings dialog as Laszlo mentioned: Story Levels in ArchiCAD Help
Katalin Takacs
