KeesW
Sizing Project Notes Box
How can I resize the Project Notes Box to a wider, and perhaps longer, default?
Kees
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
2 Replies 2
Link
Can you not just stretch it out and then quit ArchiCAD?
These settings should be saved with the lasting (ArchiCAD 9 Basic.prf) preferences.
Link.
KeesW
I know that. However, if we do it this way, someone can easily alter it. We are using this box for writing notes to be transferred to our drawings and want to use the RH edge of the box to indicate where a carriage return should go (because it doesn't have word-wrap). When we then copy the notes to our drawings, the length of the lines will about the same and the notes will fit nicely. We may alter the width of the Project Notes box but want to be able to return to the preferred width with the minimum of fuss.
Is there not a setting, somewhere, that sets the default size of this box?
