Skewed Layout
I really really need some help here quickly. We have a file that has been turning all our layouts screwy, and the guy that worked on the job originally is no longer with the company. I need to print this sheet out this afternoon, and, well, it's not going to happen at this rate. I cannot figure out how to fix it.
Steps I've tried:
1. "Rotate Orientation" on the view itself
2. Every combination of options I can think of in the "Grids & Background" dialog box
3. Setting rotated grid under "View>Grid Options>Set Rotated Grid
If this was AutoCAD, I'd say the UCS is off, but it's not AutoCAD. Can someone lend me a hand in the next few hours or so?
3 Replies 3
Erich
Select the view in the Navigator Layout book and choose "settings." Is the angle of the placed view set to something other than 0?
This will rotate a view on the layout without any changes to the view itself.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
David Maudlin
Loquinho:
See this thread:
Skewed Layouts
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Katalin Takacs
Graphisoft Alumni
Graphisoft Alumni
Dear Loquinho,
To fix the plan please try these steps:
- Select the drawing on the layout and open its source view from the context menu
- In Navigator - View Map open its View Settings
- set zooming to Fit in Window, click OK
- go back to the layout
- update the drawing
Now it should rotate back to horizontal.
I hope that helps.
Regards,
Katalin Takacs
