Mats Knutsson
Auto layouts...how to set default master layout? Solved
EDIT: like very often when not finding how to do something you post a post and then immediately you find the answer. There was a check box set as default in the settings for the master layout...of course....:)
Was testing dragging folders from view map to layout book and let Archicad automate the creation of layouts. However I don't understand how to set the default master layout? Or maybe it's not possible!?
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
BrunoH
In the Navigator right clic on  the master layout name you want to set as default, in the contextual menu choose "set as default".
ArchiCad 3.43 to 28
MacOS Monterey
printerdriversupport
Yeah, been there 😅 Post first, find answer right after. But yeah, you *can* set the default master layout—it's in the Layout Book settings. Right-click on the Layout Book, go to "Settings," and there's a checkbox for default master layout. Easy to miss, but it's there.
