Skylight Labels Show in Drawing Window, But Not on Layout
I am having an issue (AC22) in a plan view window where skylight objects are labeled, all looks fine in the drawing window, but when the drawing is placed on a layout the label disappears.
The object being labeled is a skylight on a roof plan. Other label elements on other objects are showing fine. All of the label properties are identical - using autotext to draw the label out of the note stored in the objects. All of the notes are on the same layer and all have been brought to the front of the drawing.
I can insert a "dead" text label but only so long as I don't associate it with a skylight. Is this a bug or am i missing something?
0 Replies 0
