Sliding door wall contour - cannot find the setting
furtonb
I cannot seem to find where to set the wall contour in the Pocket Door 25 object:
I want to set the inside thick contour to a more subtle pen.
It's neither the Wall, neither the Composite setting, and I cannot seem to track it in the object settings.
Wall settings:
Composite settings:
I'm not spamming the thread with all the object setting pages, but there isn't anything set to this pen.
Anyone any ideas? It's driving me crazy...
odv.hu | actively using: AC25-27 INT | Rhino6-8 | macOS @ apple silicon / win10 x64
furtonb:
Try Door Settings > Internal Door Settings > Door Settings an Openings > and check Pocket Frame to get the pen setting to work. This is AC24, so hopefully has not changed in AC25.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
5 REPLIES 5
David Maudlin
furtonb:
Look at Door Settings > Internal Door Settings > Floor Plan and Section > Frame, this pen seems to control the pocket lines. This is AC24, so hopefully has not changed in AC25.
fusionBIM-Scirrus
Thanks for the good tip @David Maudlin
Regards
Francois Swanepoel
www.Scirrus.co
​Scirrus - Future ready, digital 3D data now!
Scan2BIM - LiDAR Digital Survey - BIM As-Built - Property Compliance - Marketing Media
We are a Virtual Reality Capture & BIM Modeling Studio for 3D Digital Design, Property Compliance, Data Integration and Marketing
www.fusionBIM.co.za
fusionBIM - Architecture - BIM Implementation - Scan2BIM - ArchiCAD Training
www.BIM2fusedVR.com
BIM2fusedVR - Virtual Reality Capture, Render Studio & Matterport Service Partner
furtonb
Thanks @David Maudlin,
Unfortunately it's not the solution.
It is pen #27, that is being used, but no pen is set to this one in the object setting (I went through the GDL parameters too, nothing is using this pen):
Floor plan settings:
Based on your object (I'm using the INT version) it should appear as a 0,05mm thick black line (#20 pen).
furtonb:
Thanks, this was it.
