Split a view within a Detail Callout
I am generating tall wall sections that do not fit on our title blocks.
Is there a way to split the wall section within the detail view that we generated?
Please see the attached PDF for clarification.
Autodesk Revit has a feature that allows us to split the view as many times as we want without the need of duplicating the view in the browser.
Does AC21 have a similar functionality?
So far I have been duplicating the view and generating excess views in the browser which seems to be inefficient.
2 REPLIES 2
Erwin Edel
Not that I am aware off, this is how split details too (manually).
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Eric Bobrow
You mention that you make a copy of the View and are concerned about accumulating redundant views.
You can use the same View and place it twice (or more) on the layout, and crop the view to show (in this case) the lower section in one Drawing and the upper section in the other one; turn off the Title for the upper copy.
So you'll still have multiple views placed onto the layout, but it will actually be one View placed twice rather than two duplicated Views.
