Spot level dimension values on mesh
Bling Keeta
You can place the level dimension on the mesh using the gravity and then select the dimension text and open its preferences. Inside the dimension text preferences you will find an autotext option where you can select " To Sea Level"
to get the elevation on the mesh.
When you have 30 else spots, this seems to be a very cumbersome way, is there a better way to get spot elevations, like immediately when you click on the mesh?
I set my Project Location to 145' above Sea Level.
Project preference shows Sea Level at -145'
Mesh setting shows mesh at -145'
Section show Reference Level set to Sea Level.
Gravity tool show to mesh.
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
1 REPLY 1
David Maudlin
Ben:
All the Level Dimension texts can be changed at once, see this thread: Level Dimension Origin in Floor Plan v.19
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
