Eric Milberger
Staggered Elevation Markers
Is there a way to stagger elevation markers so they are not on top of each other.
I have floor elevations that are close together  -
The automated versions overlap each other.  Is there a way to stagger elevation descriptions for each
To redo is awkward  as I cannot just remove or change elements.
If I delete the elevation those elements delete also.
If I remove the markers they delete those items on that level
Operating system used: Windows 5003
Eric Milberger, Architect | Master Planner
3 Replies 3
Lingwisyer
Guru
I have ended up using a custom object for these situations. It's not completely bug free, but it works...
https://community.graphisoft.com/t5/Documentation/Level-Marking-in-Section-and-Elevation-for-a-Site-...
Eric Milberger
Thank-you
Eric Milberger
Graphisoft team.  What do you say on how to handle this since it is obviously a typical situation that has to be handled.  right now the most effective way is to fake it.  This is a small project.
But I don't have the time for this on our larger projects.  On my other 2 softwares, we use, you can edit the markers them selves and even step them so that they don't stack on top of each other.  It is just part of the markers.
Am I missing something?
