ā2022-12-22 02:28 AM
Those very thick lines should be narrow lines and I have tried everything. Will you please, share some insight? Thank you! Images are attached. I have the same trouble on handrails.
ā2022-12-22 04:09 PM
For the 3D pen settings, look at the Finish > Tread and Flight panels. The panel in your screen shot is for the plan display.
ā2022-12-24 01:17 AM
Thank you kindly for your reply. The solution was to change the model view options for both railings and stairs to full instead of simplified. Please, see attached.
