Stair not showing on layout
I have a stair created with a stair tool that is showing in view map but does not show in the layout. It doesn't happen with all stairs, just with this specific one so not sure what can it be. Any ideas?? please help!!
Could it be that you're using a different pen set for the drawing in the layout versus the original view? Try using the view's original pen set, it could be that the staircase's pen was rendered white in the used pen set therefore you can't see it.
Also make sure you've linked the drawing to the correct view, use "View source view" to see which view it's actually linked to.
JayV
Hi, Have you got the reason for or solution to it? I am having the same issue!
Just out of interest, have a look at the renovation status of the complete stair.
Then look at the renovation status of the structure, treads and risers.
It should be greyed out for those, but is it the same status?
