2021-04-02
02:17 AM
2023-05-22
11:53 PM
Gordana Radonic
2021-04-02 07:54 AM
2021-04-10 02:47 AM
2021-04-11 03:59 PM
2021-04-12 02:24 AM
jl_lt wrote:
The only way i have found is using cover fill for the slab and then sending the stair to the back, and then in the ground floor you send the ground floor slab to the back tooso you can see the stair in ground floor.
2023-03-14 09:48 AM
This is unbelievable!!!! Not able to hide a stair based on common logic.....
25m ago
On Document/Floor Plan Cut Plane/Relative Floor Plan Range set Show up to: Current Story.
