Story Level Lines
Greetings, I can't find a way for the story level lines to appear on the saved views for printing. Any thoughts?
4 Replies 4
RandyC
In your story settings -- make sure display & output are on.
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Thanks, that works very well. It looks like that has to be done for each elevation marker but if it's saved as a favorite, it shoud be automatically generated. Thanks again.
In the Project Map of the Navigator Palette, under Elevations you can select multiple Elevations, then right-click and activate Elevation Settings. Then you can change the setting and it will be applied to all selected Elevations.
Thank you Laszlo. Just caught your post. It's great to edit multiple items at once.
