Strange Tracker behaviour
Tracket shows incorrect values in Layout book! The right value is the one in the Coordinate box. Any ideas?
4 REPLIES 4
Come on, is it just me?
You need to depress the delta/triangle buttons in the Coordinate bar so that the values for x, y, r and a are reported as values relative to the start point, rather than the origin of the layout, just like in model view.
(I scratched my head at first since I rarely use the coordinate palette now. From my last use, I had left my x/y delta depressed, and read tracker-matching values there - but the delta for r/a was up, and like you, I was seeing not only strange values in r, but also the angle "a" was not only not zero, but it kept changing as I was shift-dragging horizontally. Made me realize what the issue was.)
AC 28 USA and earlier   •   macOS Sequoia 15.3.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
David Maudlin
kliment:
I could not reproduce your problem, but you might check Work Environment > User Preference Schemes > Tracker and Coordinate Input > Show X-Y Coordinates relative to User origin in Tracker. Checking this or unchecking this, I could see no change, but maybe it makes a difference in your set up.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you, David! This causes the problem, it should be unchecked to give the same values both in Coocrdinates and Tracker!
