Stretchy Witness Lines on Dimensions
would be a very welcome option to adjust the lengths on screen instead of using the parameter box and entering multiples of the offset distance to join up corresponding lines of dimensions. Alright I'm a neat freak
3 Replies 3
Thomas Holm
Did you try the pet palette?
Hey Dennis,
Here's an early Christmas present for you.
You can do this graphically now.
Make sure your dimension tool is active then SHIFT click to select the node or nodes where you want to stretch the witness line.
You can also select the entire dimension - then all witness lines will stretch.
But usually you will just want one or two nodes.
Then drag one of these nodes and stretch it to where you want.
Or you can select the nodes then click and drag onj the dimension line to bring up the pet palette.
One of the options there is to "Edit length of witness line"
Ho, Ho, Ho.
busted!!!
I must remember to check the guide
etc
Thank you fellas - priceless!!!
