Structural and Finished Floor Levels
Cazer_36
Hey, as indicated in the section, the structural floor level is defined as +0.15, and the finished floor level is defined as +0.25. is It possible to represent both of these levels on the plan ?
Thank you in advance for your responses.
Jp1138
Maybe you are looking for this autotext?
ARCHICAD 29 SPA (as long as the server works)
Windows 10
Jp1138
Windows 10
Yes, absolutely this!  Thank you for taking the time to respond 😀
Setup info provided by author
