ā2022-06-08 06:18 PM
Hi, for some reason, given that the walls are correctly drawn, in some edges, the surface material appears distorted (As you can see in the image). Anyone knows how to fix this?
Solved! Go to Solution.
ā2022-06-08 08:02 PM
I see thatās because the intersection between the two walls ( straight one, curved one ) if you adjust the reference lines positions it may be fixed.
ā2022-06-08 09:14 PM
Thank you
ā2022-06-08 10:06 PM
Thx a lot, If itās solved pls accept as a solution helping for finding the solution faster if anyone faced the same challenge.
