2022-06-08 06:18 PM
Hi, for some reason, given that the walls are correctly drawn, in some edges, the surface material appears distorted (As you can see in the image). Anyone knows how to fix this?
Solved! Go to Solution.
2022-06-08 08:02 PM
I see that’s because the intersection between the two walls ( straight one, curved one ) if you adjust the reference lines positions it may be fixed.
2022-06-08 08:02 PM
2022-06-08 09:14 PM
Thank you
2022-06-08 10:06 PM
Thx a lot, If it’s solved pls accept as a solution helping for finding the solution faster if anyone faced the same challenge.
