SOLVED!
Surface color and renovation filter
Dontknow
How can I set the change of surface color with the renovation filter?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
1 ACCEPTED SOLUTION
Solution
David Maudlin
Dontknow:
Set the Surface under Graphic Override Rules > New Elements (or other renovation setting) > Surface, then that renovation setting needs to be set to Override under Renovation Filter Options.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
2 REPLIES 2
Solution
David Maudlin
Dontknow:
David
Dontknow
Thnx for your info.
I'll look into it.
New subject for me.
ArchiCAD 25.
