‎2012-09-15
12:02 PM
‎2023-05-22
11:58 PM
Gordana Radonic
‎2017-09-05 12:13 PM
‎2017-09-05 12:28 PM
‎2017-09-05 12:55 PM
‎2017-09-05 05:17 PM
‎2017-09-05 05:45 PM
Link wrote:Or even easier: just always put the plus or minus
When about to place the window, hover on the corner and type X1200+ and hit enter. I think of the + as meaning relative to where the cursor is. You can also input X-1200+ to go left (-X). Similar for Y.
‎2017-09-05 06:41 PM
‎2017-09-05 08:31 PM
runxel wrote:But that's relative to the origin right? So you'd need to set the user origin first?Link wrote:Or even easier: just always put the plus or minus
When about to place the window, hover on the corner and type X1200+ and hit enter. I think of the + as meaning relative to where the cursor is. You can also input X-1200+ to go left (-X). Similar for Y.behindthe number, if you want it to be relative. If it is in front, it's absolute.
thompsonmp wrote:No equations, but you can enter imperial dimensions as decimals.
Thanks guys. Tips like those are a massive help
Speaking of + and -, can you input formulas in Archicad?
I used to enter e.g =235+568+1392 into dims/temporary dims in revit or more complex formulas. Typing imperial dimensions in whilst working in metric proved handy sometimes too
‎2017-09-06 12:31 PM
Link wrote:Nope 🙂
thompsonmp wrote:Not at the moment, but I think there was a wish already somewhere here.
‎2017-09-06 04:38 PM
thompsonmp wrote:You can, after either hitting X, Y or R (and result will depend on what you use), keep using "+" or "-" after each number.
I used to enter e.g =235+568+1392 into dims/temporary dims ...
‎2017-09-07 04:16 AM
runxel wrote:I've not seen the edit origin move from coordinate input alone, but I guess it could be possible depending on the User Preferences in your Work Environment and your use of the Coordinate Box.
Nope![]()
(and a little bit yes)
Doing this will actually set the user origintemporarilyto the point where your cursor is at that point.
sinceV6 wrote:Great info!
When moving something, you would CTRL-D, click, R or X, then 235+ 568+ 1392+, ENTER
After each "+", snap guides will show.
